Menu
4-Play Controller Adapter barebones kit
Item is not in stock.
Price:
EUR24.00 price includes VAT
EUR20.00 price excluding VAT
VideogamePerfection.com is now proud to be the official UK and European distributor for the 4-Play controller adapter kits (customers in the USA can purchase them here). These amazing little adapters are ideal for anyone running emulators on their PC, Android or other USB compatible device. The unit works with Windows, OSX, Linux, Raspberry Pi, most Android devices and the PS3.
The 4-Play is a universal controller adapter that allows up to four people to play simultaneously, with any compatible controller. It’s compatible with virtually every controller and peripheral in existence (see tested compatibility list). It uses low cost adapter cables which allow controllers to plug into its HDMI-like ports. This gives you an unparalleled capacity to play with different types of controllers at once or to swap and configure controllers on the fly. Find out why we think the 4-Play is so awesome by reading our review here.
Use your favourite controller with any PC game – Want to play Shovel Knight with a real SNES pad? Now you can! (Some games may require controls to be reconfigured, or the use of 3rd party software such as X360CE).
Quickly and easily connect controllers for multiplayer sessions – Crack out the laptop and the 4-Play then fire up TowerFall Ascension or your favourite local multiplayer game. Choose any classic controller and it’s game on. Doesn’t matter if you prefer a Saturn controller and your friend prefers a SNES controller, you can use any combination of your choosing.
Play your emulated games with the controller they were designed for – No more clumsy mappings for N64 games, no more being told to press X when your controller doesn’t have an X button. Play the game the way it was meant to be played.
Engineered by gamers for gamers, input lag minimised – Designed in the USA, the 4-Play units have been expertly designed to minimise input lag, eliminate button ghosting and other problems inherent with cheaper USB controller adapters.
In addition to the controllers it already supports, 4-Play can be easily updated to support new ones. New adapter cables can be designed should the need arise. The 4-Play’s design has been based on the concepts of adaptability, authenticity and value, since the very beginning.
Barebones kit includes the 4-Play device and USB cable and 2 Nintendo GameCube cables
We have a limited number of these barebones units so order soon to ensure you get yours.
What about different cables?
You can purchase additional cables here:-
Alternatively, if you’re building a complete emulation box, save money and buy our complete kit here.
Technical support and updates
Instruction manuals for the 4-Play are available to view online here.
Firmware updates can be downloaded here. See the instruction manual for details on how to update the firmware. Remember you need to update the firmware for each of the four controller ports.
Community based technical support is available at the Bliss Box forum. You can also contact Bliss Box directly for 1 to 1 technical support.
Customer Reviews
Submit your review
1
2
3
4
5
Submit
Cancel
Create your own review
4-play controller adapter barebones kit
Average rating:
 0 reviews
No comments
