Menu
Extron to SCART (output) cable
Item is not in stock.
Price:
£27.48 price includes VAT
£22.90 price excluding VAT
Connect your Extron Crosspoint or similar commercial grade RGB switch to any SCART compatible display or upscaler. This cable has 4 BNC input connectors and one phoenix audio stereo connector wired for audio output (unbalanced). The cable outputs to a male SCART plug and is 90cm/35.5 inches in length.
This cable also includes a 460ohm resistor on the sync output to properly attenuate the output. This is necessary in order to be compatible with the Extron Crosspoint as the Crosspoint internally boosts and attenuates sync to TTL levels.
Customer Reviews
Submit your review
1
2
3
4
5
Submit
Cancel
Create your own review
Average rating:
 0 reviews
7 comments
  1. Jarryd Peasley says:
    Would it be possible to get this cable in a custom length? I have an Extron Crosspoint 450 Plus 3232 and I need a good amount of length on the BNC / phoenix cables to comfortably connect them without stress on the cables. I would also like to have the entire cable itself longer than 90 cm if possible.
    Obviously I would be willing to pay more for the additional length / effort put into the cable.
    Thank you for your consideration!
  2. John says:
    Do people typically require something such as a SyncStrike in line between Extron and OSSC when using this cable?
  3. Mark says:
    Any ideas when you will have these back in stock?
    Thanks
  4. Stefan says:
    when will this cable be back in stock?
  5. kayanel says:
    Please get more of the EXTRON TO SCART (OUTPUT) CABLE. Thanks
Get your OSSC
