Menu
Nintendo SNES / Super Famicom switchless region free mod
Item is not in stock.
Click Below For More Images:
  • Nintendo SNES / Super Famicom switchless region free mod
Price:
£78.00 price includes VAT
£65.00 price excluding VAT
Sorry - Not currently available
All repair/modification work is carried out subject to our terms and conditions. Once you have placed your order, details of where to ship your hardware will be sent to your e-mail address. Prices do NOT include return postage. To estimate return postage we recommend Parcel2Go. Parcels will be returned by Royal Mail or UPS only.
The SNES Super CIC mod is the best way to modify your SNES or Super Famicom console to play all region games. You can change the consoles region by holding the reset button or, with our very latest SuperCIC boards, by using a button combination on the SNES controller. You can also switch between 50Hz, 60Hz, or auto-detect mode, allowing you to play compatible PAL software at 60hz, or at the speed originally intended. This mod has 100% compatibility with import games, even those with more sophisticated lock-out technologies. If you’re sending in a US SNES we can also remove the internal plastic lugs that prevent PAL and Japanese cartridges from inserting (playing American games on European or Japanese consoles will also require an adapter or for the cartridge slot to be physically widened).
Unlike our competitors we use only the very latest, high quality SuperCIC boards in both our 1 chip and multi-chip installations. There is no better or more reliable SuperCIC mod than this on the market. Enjoy a true, region free SNES console!
Note:- We strongly recommend playing your SNES console using an RGB cable. On some televisions, import games may appear in black and white when using composite or S-Video connections.
Due to minuscule differences in video timings between PAL and NTSC consoles, users connecting modified PAL consoles to HDTVs (either directly or via an upscaler such as an XRGB) may experience stuttering/juddering during scrolling in games when playing in 60hz. This is not a fault with our modding process (we’re just the only website honest enough to tell you it could happen). This does not affect CRT users, see this page for more information. Since the SuperCIC board for the Super Famicom Junior/1-chip consoles includes a replacement clock crystal, this mod is NOT affected by the scroll stutter issue.
We can fit this upgrade to the original SNES or the later revision, so-called “1-chip” SNES/Super Famicom consoles. 1 Chip consoles are later model consoles and all Super Famicom Junior and SNES Mini consoles. While all Junior/Mini SNES consoles are 1-chip (that we are aware of), most of the original design SNES/Super Famicom consoles are multi-chip. If you are unsure if you have a 1 chip or multi-chip console, order the cheaper mod and we’ll contact you if we find your console is a 1-chip.
Want to DIY fit your SuperCIC board? Click here.
Operating instructions
SuperCIC user manual PDF – Click here to view/download.
Thanks to both borti4938 and Ikari_01 for making this mod possible. This mod is based on the open source design by borti4938 and Ikari_01. For more information, see the Github page here.
Order 2 or more SNES mods at the same time and receive a £5 discount on your order.
Customer Reviews
Submit your review
1
2
3
4
5
Submit
Cancel
Create your own review
Average rating:
 0 reviews
4 comments
  1. Glyn says:
    Hi
    I’ve got the new SNES Mini on pre-order and want to know if this mod will be available for this model and what the current waiting list is? As I’ll be getting it in September.
  2. john lawless says:
    hi i have a snes 1chip-01 can you fit this region free board with a rgb amp aswell and if so would you consider discounts if brought together
Get your OSSC
