Menu
Open Source Scan Converter (OSSC) (Reserve list only)
Item is not in stock.
Click Below For More Images:
  • Open Source Scan Converter (Reserve list only)
Price:
£151.80 price includes VAT
£126.50 price excluding VAT
Limited stock – Please do not share this page with your friends. Please only order this product if you have received an e-mail invitation. Other orders will be cancelled. One unit per customer only for now and no queue jumping, thanks!
Important! – We give you the option to purchase the OSSC without power supply unit (PSU) or remote, so that you can use suitable replacements you may already have yourself. Information on using alternative remotes is available here. Please note the specs of the required PSU carefully. You require a unit that outputs DC 5V with at least 1 Amp. The tip must be 2.1 x 5.5mm and centre positive. Please note that damage caused by using an incorrect PSU is not covered under the warranty.
Note – Audio upgrades are out of stock but more stock is on back order. If you want one, go ahead and order one and I’ll reserve you an OSSC until they come in. Power supplies and remotes are currently fully stocked.
It’s finally here! The ultimate lag-free retro gaming linedoubler and processor hits the market. Now there’s an affordable way to use your retro consoles on your PC monitor or TV in perfect quality. No more bad upscaling, no more interlacing artefacts, no more high input lag, the OSSC is a dream for retro gamers and collectors!
What does it do?
Processes (line doubles) retro games with NO input lag – Unlike other scalers, such as the XRGB Mini, the OSSC works on individual scanlines rather than a frame at a time, that means there’s no input lag whatsoever (well, a few nanoseconds if you really want to be precise).
Eliminates ugly deinterlacing artefacts and bad scaling – Connect most retro consoles to your TV and if you get a picture at all, it’s likely to be ugly. Bad scaling combined with deinterlacing (which should never even be applied to 240p material) will ruin the picture and make you wish you had your old CRT back. Well, worry no more! OSSC converts the image into a 480p or 720p (where compatible) image that is correctly displayed and processed. EVERY special effect, from 240p drop shadows to striped sprites, is rendered correctly.
Converts SCART and Component to DVI/HDMI – Feed in a 480p component video signal from a Wii and get out a perfectly processed 480p DVI or HDMI (with a simple adapter) image. The quality is flawless!
Convert VGA to DVI/HDMI – Connect a Dreamcast directly to the unit and enjoy HDMI processing of all your games, not just those that support 480p.
Fast deinterlacer – Fed up with high input lag on interlace games? The OSSCs deinterlacer is lag free! Note that this does however mean there’s a drop in picture quality for interlace sources, but this is unavoidable. A pass through mode, where interlace signals are sent directly to the TV for processing instead, is also included.
For more information, click here.
What are other people saying?
Don’t take our word for it, check out these other reviews around the web.
OSSC – Fudoh’s review
OSSC – Review by Blizz
Documentation, support and returns
Firmware updates
Support Forum
Quick start guide
OSSC Wiki
In addition to the standard 1 year EU warranty, we’re also giving a one-month no quibble return for all units. Test the OSSC in your setup and if it doesn’t work, return it to us for a full refund. All we ask is that you pay return postage and send the complete unit and any accessories undamaged. Contact us here if you need to return a unit.
Technical specs
Inputs
  • 1 X SCART – Supports RGBs (clean csync, cvideo sync, luma sync), RGsB, Ypbpr
  • 1 X Component video – Supports Ypbpr and RGsB signals
  • 1 X D-SUB15 (VGA) – Supports RGBHV, RGBs, RGsB, Ypbpr
  • Composite video and S-Video are NOT supported and require an adapter/transcoder
Outputs
  • 1 X DVI-D (digital only, no audio unless audio upgrade board is installed). Full-range 24-bit RGB output through DVI/HDMI
  • 1 X Analogue audio 3.5mm
Supported input resolutions
  • 240p/288p/480i/576i 15khz
  • 25Khz medium-res modes
  • 480p/576p/720p 31khz
Supported output resolutions
  • 240p/288p -> 480p/576p or 720p line triple (compatible displays only)
  • 25Khz medium-res modes -> 480p
  • 480i/576i -> 480p/576p or pass-through
  • all 31khz resolutions passed through
Other features
  • Back lit LCD
  • SD Card socket for firmware updates
  • JTAG connector
  • IR reciever
Power requirements
  • DC 5V 1 Amp – 2.1 x 5.5mm positive tip
Customer Reviews
Submit your review
1
2
3
4
5
Submit
Cancel
Create your own review
Average rating:
 0 reviews
Reserve your OSSC
Want to reserve an Open Source Scan Converter? Sign up to the Newsletter by clicking here.
Categories
  • Opinion (5)
  • Preview (1)
